XKR Factory Alignment Specs Needed For Proper Up To Date Alignment The Way It Should
Received 2,192 Likes
the specs have never changed for XK's only Stype's. And having the latest most up to date software and machine does NOT matter. Our software from Hunter was just changed and still has incorrect Stype specs. I go in and manually enter, change, and save the correct specs. Whatever they have Im sure is correct, now wether or not they know what they doing with them is something different entirely
mel98xk8 (06-07-2014)
Brutal and the other techs always recommending starting with the factory specs (you'll find them in the Jaguar Specification Document in our FAQ sticky at the top of these forums to download), then 'load' the suspension to take any account for typical vehicle toe gained by moving forward, then readjust back into spec. Most regular shops won't load it, then when you end up driving it, the wheel ends up too far toe-d out, resulting in additional inside tire wear. (more from just a little negative camber that our cars 'settle' into over the years.)
FS[NorthEast]: Jaguar XKR Wheels for Sale
Griffbritgreen
07-27-2016 05:43 AM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
