XKR Front Spring Install (Position)
Hello,
Before I ask, maybe a dumb question, thanks to all on this forum for making a "new to Jaguar" owner feel more confident in repairing my XKR. My uninstalled parts box is filling up so I wanted to ask about the front springs.
I have all the parts I need to assemble the front struts ahead of time, then just remove and replace the old.
I notice some paint marks on the new springs. Dumb question, but does it matter how I install the springs in relation to the shock. Or should the paint on the spring be facing the outside? inside? does it matter. I have a well made spring compressor, and putting new boots and stops on too. I hope this makes sense.
Thanks again,
Thanks again,
R3Wood (05-07-2015)
Thanks for the replies.
I see the white plastic at the bottom of the spring attached.
So, over the shock, lower seat, spring packing, spring, bumper, dust cover, upper mount.
Also, the upper mount I got from JagBits is loose as in not attached from top to bottom with urethane in between. Do they come this way?
Thinking about it, there was a little play in mine when I replaced them. But once under load of the spring and the weight of the car, it aint goin anywhere.
R3Wood (05-07-2015)
Make sure you clean the threads on the studs first. They likely came painted or powder coated and will strip and/or snap off if the nuts do not fit well.
Beardy
09-18-2015 10:00 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
