XKR fuel pump replacement
Also download a copy of the JTIS that you can find in one of the stickys.
By the way,you have two pumps.
I been there and done it,take your time and you will get it done,just a little dirty and sweaty.
phyllisita (08-27-2013)
![Red face](https://www.jaguarforums.com/forum/images/icons/icon11.gif)
Coupes have strap ,coverts do not.GET A COPY OF JTIS AND IT HAS ALL THE THINGS YOU WILL NEED TO DO ON BOTH THE CONVERT AS WELL AS THE COUPE.You will also have to get under the car and remove the fuel lines before you can remove the tank.Please check on how to use the search function.It's in the new members area, also please look over the General area.
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
Got this from Alldata for the convertible. Sorry if it is incorrect! As for the pump replacement this link is in the FAQ http://www.gusglikas.com/AutoRepairFuelPump.htm I hope it helps!
Today, I learned that the XK8 gas-tank removal procedure does not apply to the XKR /2000. The XKR has a heat shield on-top of the differential that hiddes the fuel lines going into the tank. I am going crazy trying to figure out how to do it. It looks like the differential will need to come down. Crazy, even by Jaguar standards!
Member "bgoldstucker," I just did this (Fuel Pump Replacement) two weeks ago on my 2003 XKR.
There is precious little room above the diff. to get your hands, tools etc through and past the heat shield and the access hole in the floor of the trunk - but you CAN do it! Though, I must say, it's by far the most frustrating part of the job.
Member "AVOS" in posts number 52 and 56 of this thread
https://www.jaguarforums.com/forum/x...tunists-61394/
shows how to make a special tool that would have made this job MUCH easier for me.
Make the tool and proceed carefully - You CAN do it! A person to help you on the top side while you are laying on your back, squeezing your hands into places that will scrape them up - and then fill the scratches with greasy dirt would be helpful too.
I attempted to pull the tank on my 99 XK8, and it's pretty difficult job on your back. You just cannot maneuver around, and it's a dirty job. It's a 2.7 hour on the base rate manual.
Luckily, we can get Jag mechanic work done @ $50 per hour. Including a roll back ride to the shop, it was well worth $190 to get it done. The older fuel pump is off a Taurus, and it was something like $58 @ RockAuto.com. Autozone wanted $98 for the part. Then, you have to get a "sock" and a fuel pump at the same time.
I'm just thankful I found a local shop that has Jag experience for such a reasonable rate. For the more difficult problems, I'd take the car to Memphis to a 23 year Jag dealer mechanic that grew up across the street from my wife.
I hope this helps http://www.gusglikas.com/AutoRepairFuelPump.htm
![](https://cimg5.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1500x2000/e9008cf8_9d6e_4fdb_b882_093c124f47cf_84938c8805d8f129c45ebf55866fd99e2cffe154.jpeg)
On my car, I bought the Airtex pumps and both leads from the dealer (pumps were $50 for a pair at the time with all the crap like the sock and clamps and such; wires were $50 each). It's a doable job, but definitely more trouble than $190.
I'm faced with the same thing.
Luckily for me, a previous owner already created the easy-access top hatch mod that avoids pulling the gas tank.
The mod is described here: https://www.jaguarforums.com/forum/x...-access-118362
If he hadn't already created this, I was prepared to do so.
Here's a pic
Here's a pic
![](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/85105d1400765849-fuel-pump-access-dscf5045.jpg)
Johnken (07-20-2019)
Forum Members (yes you!) that respond to people who come to the forum for help, instructions, clarity and who are feeling desperate, in over their heads and are told to - GO ON LINE AND LOOK IT UP,,,,, or paste a link,,,, need to understand what a forum is about and,,,, get their heads right. Jus say'n
Telling people to follow a link and go figure out AIN'T forum-ing... It's lazy, snobby and trifle vanguard-ish corny..
This is a 10yr old post and and that web page has been moved to
JagRepair.com - Jaguar Repair Information Resource
Gus
Gus
Johnken (12-15-2019)
