XKR heads
Old 03-24-2017, 02:40 PM
BobRoy's Avatar
Default XKR heads
Will 04 XKR heads work on a 01 XKR. I know the 04 is a 4.2 and the 01 is a 4.0 but the engines are generally the same. What differences if any between the heads and if there is can the 04 be adapted to the 4.0.
Old 03-25-2017, 07:34 AM
ccfulton's Avatar
Received 1,108 Likes on 764 Posts
The intake is changed with different port locations and I believe that the cam position sensor is made differently. Cams are also slightly different in their profile.
There are some threads in the engine section that discuss differences between the AJV8 variants.
https://www.jaguarforums.com/forum/j...highlight=port
BobRoy (03-25-2017)
