XKR MAF replacement
XKR MAF replacement
Hi
Just hoping someone can recommend a good source for an MAF sensor. I have a leak but if I can get a replacement (new) MAFS cheap enough I might try swapping it to see what happens.
Part number for my VIN is LNE1620BB
SNG Barrat have it for £140, just wondering if theres an aftermarket or ford etc. part I can use. Theres loads of XK8 versions on ebay for around £40, but I can't see one for an XKR
Thanks in advance!
Thanks in advance!
You're right - these are hard to find!
Try this link:
Jaguar MAF Mass Airflow Meter LNE1620BB XJR XKR
This is supposed to be an aftermarket equivalent to LNE1620BB at £50.
Try this link:
kreyszig (03-18-2014)
Right my peak value wasn't at 100%, it was 216.7 at 62% throttle
At 100% throttle I have 9 values (couldn't keep it at 100% for long!):
190.96
176.08
169.31
167.79
160.9
156.19
154.74
148.58
108.52
At low throttle my values are around 4.8-5
Hows that looking? Thanks for your help so far!
Edit: Note that these are not in time sequence, I hit the throttle a couple of times and these are just the ones at 100% throttle sorted max->min
190.96
176.08
169.31
167.79
160.9
156.19
154.74
148.58
108.52
Dont mean to hijack this thread but title is what I was looking for.
I am wanting to replace my MAF Sensor and wondered if the ebay one here if fine for replacement.
Mass Air Flow Sensor MAF for Subaru Impreza Forester 2 0L 2 5L 22680AA310 | eBay
I have tried to clean min with CRC cleaner but it still happens from time to time. Actually...when i removed the unit the o-ring was not in the best of shape. So if someone knows where I can get that size of o-ring that would help too.
Thanks in advance
Thanks in advance
Beardy
09-18-2015 10:00 AM
