XKR Radiator Fan Disconnect - HOW?!?!
Old 05-03-2016, 03:03 PM
scardini1's Avatar
Default XKR Radiator Fan Disconnect - HOW?!?!
Hi guys,
I believe that the last time I disconnected the right fan electrical connection (to release the S/C belt), I did it from below while on a lift. I don't have the lift option right now, and for the life of me, I can't figure out how to release that connector from above.
I don't have very large hands, but there is NO room to "play" with this thing. Can anyone explain exactly how that connector releases (i.e., squeeze the bottom, etc.) and how you manage to do it from above?
Thanks !!!
Jim M
Old 05-03-2016, 09:16 PM
Jag#4's Avatar
I have small hands as well, but was unable to disconnect from the top. However, it is pretty simple from below on jack stands. No lift needed.
Don't have the pictures anymore, but IIRK they are "push the clip" type connectors. I'm sure someone will jump in with better info or pictures.
mjlaris
09-06-2020 04:07 PM
orangeblossom
04-15-2016 01:05 PM
o1xjr
02-17-2016 06:10 AM
User 070620
08-13-2015 12:04 AM
Sentinelist
06-10-2015 10:31 PM
Quick Reply: XKR Radiator Fan Disconnect - HOW?!?!
