XKR seat angle
hello all and a first post from a new member, have a 1998 XKR that has I hope a minor problem in that the seat angle won't adjust on both seats the mechanism for the back and forward plus height etc. seem ok but just can't seem to tilt the seat back....just an annoying click! anyone have any ideas?
thanks for getting back, it seems that both seats are stalled and won't move either way all I get is a click....the other seat switches work fine maybe I need to replace the switch unit?
cheers
cheers
If you are hearing a click when you hit the switch, then most likely the switch pack is not the problem.
By far the most common problem in these cars with the seats is the control module. There is one for each seat and they are located under the cushions. Do to a poor design, the copper electrical traces on the printed circuit board module rubs agains the plastic housing and eventually create open circuits. If you or someone you know is handy with a soldering iron, I can post a link on how to look for and do this type of repair. There are also companies that do module rebuilding. The final alternative is module repalcement, but that is the most expensive.
There is a lesser chance that the problem is chafed wires under the seat. This is also a known issue, but not quite as common.
The other possibility are two bad motors, but I think that is least likely.
would be grateful for the link on repair of the printed circuit module,
thanks
betty
thanks
betty
See http://forums.roadfly.com/forums/jag...9317317-1.html
and https://www.jaguarforums.com/forum/s...+module+solder
Please let us know how it goes! This is one of the best car forums around and your feedback is important to us.
