XKR Silverstone blank nav screen
Hi all,
i am restoring an XKR Silverstone coupè. I am facing an issue with sat-nav: as i switch it, the screen stay black, but i am able to see it is switched on (a little glowing surround the screen). Seems more that is stucked, like if somebody has tried a bad update. Dvd is loaded correctly in the bay, and the dvd is original. I have read in some old thread that should exist a startup dvd, but i have not been able to find it. I enclose a picture of the car, as you can see rims are under rebuid......
Any suggestion?
Any suggestion?
[QUOTE=Lucadelta;960325]Hi all,
Any suggestion?[/QUOTE
Will the Nav DVD eject? If so it's worth cleaning the disc and trying again. Also worth checking all the connections at back of Nav and DVD changer in the boot. The same thing happened on my 2001 XKR - had intermittent problems with blank Nav screen - managed to keep it going for a few months but then packed in completely - I ended up replacing the whole Nav unit. Managed to source one on ebay for about £30 at the time.
Steve
Steve
If we're discussing other options, I should throw the nav-to-3-gauge conversion into the ring. WhiteXKR, a member here, offers a conversion kit that makes it very simple to switch out the nav for the factory 3-gauge cluster.
The gauges are much more useful (w/ RealGauge, especially) and classic-looking, in my opinion, than the outdated factory nav. I'm not sure what shape your dash veneer is in, but that is the only potential for added expense; you'll need a set that can accommodate the gauges.
