XKR timing cover versus XK8
Welcome to the forum Burra,
(I've moved you tech question from General Tech Help section to the XK8/XKR section.)
You'll get the full answer here but I think on your MY the main consideration is VVT or non VVT rather than NA or SC.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice on posting to the forum.
The 1999-2002 XK8s do NOT have the Front Cover mounted VVT Connection.
All XKRs do NOT have any VVT Connections.
However, your 1999 XKR has a AJ26 Engine. The 1999-2002 XK8s have a AJ27 Engine. The Front Covers may not be the same. This may mean that there is no compatible XK8 Cover. (you may need a AJ26 only Cover without the VVT Connections).
xjrjag
10-27-2021 11:48 PM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
