XKR vs STR.....
XKR vs STR.....
My friend with a stock SType R and I dragged a few times last night after work. We raced a little over a 1/4 mile. I'm happy I won the 3 times but barely a full car length. Hell if I didn't have the exhaust mod and filter would I even won at all?!
My car is in top condition, great tires, etc.. I had a 1/4 tank of gas no passenger. He had a passenger and his gas was about the same. I really thought I'll beat him a lil more convincingly. I know... same engine and tranny... I know... but still! I'm also aware that the Silverstone and earlier 4.0 are a couple tenths faster because of the couple hundred pounds added to the 4.2 cars. I've seen times of 12.9 - 13.2 posted for these from the mags and 13.0- 13.4 posted for the 4.2 with the str having 13.3 to 13.6.... if it was the 4.2 XJR I would be surprised with its light weight aluminum body.
I need to get a lower pulley for xmas and go get him again. I may go for some custom magna flow hi-perf cats. What else can I do without breaking the bank? I'm only trying to have a 12.6 2005 XKR.
Juke
Juke
I have the lower pulley mod and it does make a big difference. However, the biggest difference I've seen is from the addition of an LSD and rear axel ratio change to a 3.27 (vs. stock 3.06). However, I understand that a rear axel ratio change is not possible on a 4.2 liter XK8/R. I can't remember the reason.
Mark
Mark
I don't street race on neighbor roads. We were at an industrial park and the Fed ex guys thought our cars were 2014 models!
It helps the high end, not the low or mid-range. Jaguar states that the XKR tops out at 175 mph. Unless you're on the track and have very large b*lls, it is unlikely any of us will ever see that speed, especially since the ecm limits speed to 155 mph. What's important to me is the low and mid-range. This is the reason why, in addition to the lower pulley mod, I changed the rear axel ratio but left the exhaust alone. That, and I also use my XKR as a real GT should be used, for very comfortable long range cruising.
Mark
Mark
Both are right
It is a misconception that it is backpressure that improves low end torque, it is really exhaust velocity that is important.
An engine is essentially an air pump, and removing restrictions on the outlet side is a good thing for power. Less work goes into moving the waste gas out and more work goes into turning the wheels.
On a supercharged car, since the blower is directly tied to the crank, it moves an amount of air proportional to the rotation. An Eaton isn't a perfect positive displacement device but for simplicity you can think of it that way.
You may in fact decrease the observed boost level because with less restriction to get the exhaust out, more fresh air can get in. And since there is a fixed amount of air being pumped into the manifold with every revolution, the pressure goes down, but not necessarily the volume of air that gets into the cylinders.
Lower boost can actually make more power in the right situations.
The thing that a big exhaust system can do is decrease the velocity of the exiting gases. At a high velocity, they create a sort of vacuum that helps to sucks the exhaust out of the cylinders.
Going with a large pipe, decreases exhaust velocity until you get to higher RPM, where the air pump is making more exhaust gas and the velocity comes back up to get good scavenging.
So, you can lower boost and make more power and you can also have a big free flowing exhaust and lose power in the ranges you spend most of the time.
It's all about balance.
PaulCarr (12-10-2014)
You will never know which car/driver is quicker until you take it to the track. Was your traction control on? That can kill performance. I beat many quicker cars because of better reaction time and/or 60 ft time. Also, a full car length is nothing to sneeze at.
Rear gears is what our cats need. The DOHC small 4.0 displacement engine, struggles to get in its powerband fast enough.
3:27 gears would be the perfect all around solution, however,
1. I understand this will cause a "incorrect gear ratio" error of some sort, and any tune, even minor, ive been told is $800, even if all you have changed is the gears.
2.Don't know of anyone that has limited slip setups and gears for us.
Maybe someone can correct me if there is a better solution to this issue.
Couple of things
I've been told that doing the lower pulley on a 4.2 is a waste of money because it is already bigger than a 4.0 (which is what the lower pulley upgrades were made for). I'm told the difference is negligible. The other thing about a 4.2 is they screwed around with the sensors and you can't put in a lower rear end (they do make them) limited slip without throwing a code. There are a couple folks working on a fix for this but I'm waiting until one of them reports it actually works as that part isn't cheap and I'd hate to have to take it out again. If you do go to a smaller pulley you will have to do something about the intake temp as it will spike. The Eaton's really heat up the air and the more you work them the hotter the air gets removing the power you would otherwise gain. Consider a chiller killer but both isolate the cooling circuit and put in a second pump otherwise you don't get enough heat transfer. I didn't do either and it isn't getting cold enough (I do have the smaller pulley).
This is true. You can get the 3.27 rear axle ratio out of another Jag, I forget which one. XKRacer can help with that, however it does require reprogramming the ecm. This costs about $2000. Also, as stated above, This will not work on a 4.2 model. I bought mine from another forum member. But for the record, it is now seriously quick off the line. If I forget and step on it when a red light changes, I scare the sh*t out of myself.
Mark
