XKR VS XK8 4.0l engine Fuel pump position
Recently someone with a 4liter XKR posted wonderful photos of the fuel pump position, including a ruler. Now I don't know about you,but when my XK8 fuel pump fails, I'll be drilling that hole for easy access. Its gonna happen sometime, just wa t to be prepared.
Here's my question: since the XKR uses 2 fuel pumps, are either of them
in the same position as the 1 pump in the XK8?
So before I, or anyone else, uses those great photos for dead reckoning I wanted to check. Thanks.
John
John
DavidYau (09-04-2019)
Johnken (09-03-2019)
The SINGLE PUMP tanks are pretty much the same as the twin pump tanks. The twin pumps just have another place in the sump area for a second pump to be secured with a screw to the top area of the sump sheet metal.
I thought about installing a second pump and a SC EVAP flange and harness so that I could install a second (redundant) pump in my normally aspirated XJ8 in case of a failure but the pumps last 10 years or 100K miles so 'meh'.
bob
bob
