XKR vs XK8 Speaker Upgrade
I'm almost there with my '04 - fitted an Alpine 5-channel MRP-F320 amp (40W RMS x4 + 140W RMS x1) and Infinity reference speakers, just got the sub to install and connect, then balance the whole lot up. I used 16.5cm 2-way component speakers at the front, with the tweeters in the dash, and co-axial's in the rear. The sub is an infinity 8" unit.
A nice surprise was finding all the wiring to the tweeter positions already connected, so I simply installed the crossovers for the front speakers in the centre console, breaking in at the nig yellow plug to route the head unit outputs under the rear seat and into the boot where I mounted the amp above the cd changer. Heavier cables then return from the amp to the yellow plug, feeding back to the speakers. Don't worry about the longer cable runs, the infinity units are 2 ohm so the amp probably sees around 3 ohm allowing for cabling.
How does it sound? So far so good - a bit bright on the treble maybe, but overall a dramatic improvement and it'll be better still with the sub.
