XKR - When Did The Timing Chain Guides Go Metal
Good Morning,
I've been researching the threads on this issue, but I can't (unless missing something) find out when the tensioners went from plastic to metal. I will soon be taking my 2002 XKR with a 12/01 build date in to an indy shop to have the rear end leak repaired and would be a good time to have the tensioners done as it is outside of my area of expertise.
Sounds from the threads that if all else fails I could remove a valve cover and look.
Thank you,
Rob
Thank you,
Rob
Dr. D (06-09-2020)
zray (06-25-2024)
Not sure if this helps anyone but my car (VIN SAJDA41BX2PA25864) has the metal guides. Had my mechanic open the engine to check a couple weeks ago. We have owned the car since new and can confirm that we never replaced the guides.
