XKR2003 P1338 Fuel pump not working
Old 06-28-2013, 01:10 PM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
Have you checked the exciter ring?
  #42
Old 06-28-2013, 01:14 PM
Gus's Avatar
Gus
Gus is offline
  #43
Old 06-28-2013, 03:34 PM
jaguarlars's Avatar
Thanks!
  #44
Old 06-28-2013, 04:55 PM
jaguarlars's Avatar
One more shot. Reinstalled the moduls, ECM, BPM and KTM. Car will still not start but the P1338 disapered and instead P1234 comes up and that has not been there before. If this is a step forward I don´t know...
  #45
Old 06-28-2013, 09:15 PM
Gus's Avatar
Gus
Gus is offline
Did you have the battery disconnected when you R&R your modules?
  #46
Old 06-29-2013, 01:01 AM
jaguarlars's Avatar
Reinstalled maybe was the wrong way of putting it. I updated all moduls with the IDS/VCM.
  #47
Old 07-02-2013, 11:31 AM
Received 2,192 Likes on 1,358 Posts
Originally Posted by bobf
if the system thinks the fuel tank is empty it should shut down the pump to avoid burning it out w/o fuel to lubricate the pump.
Check range to empty.
nope wont happen, and I have no usefull input without cracking open diagrams and just too busy with people out sick, vacation etc for indepth diag. was mentioned on the exciter ring around the ign barrel. This need to show 33.4 ohms or bad. This IIRC will inhibit fuel pump, but not explain stall when driving
toronadomike
08-07-2022 03:41 PM
Sprayall
05-30-2021 08:13 AM
Russ Graber
02-23-2019 11:59 AM
alpecsa
09-07-2015 11:55 AM
Sprayall
09-03-2015 07:49 PM
Quick Reply: XKR2003 P1338 Fuel pump not working
