XKR's don't have secondary tensioner problems
Received 6,319 Likes
The following 2 users liked this post by Norri:
crossfireguy25 (08-20-2014),
Old_Doc (08-19-2014)
Don't Judge him to quickly, early XK8 cars outnumbered the XKRs substantially, so by shear mathematical chance it wouldn’t be unusually he would have never have seen a XKR with an issue (in real life the Rs’s suffered just as bad as the 8’s in %).
You also have to realize here in the US we didn't get an XKR with an AJ26 engine. The first US cars were 2000 model year. So I have to actually agree with him as we never had an XKR come in with broken tensioners.
That's really the question here isn't it?
You are asking a different question. I responded to the comment about tensioner issues on an XKR. I have never seen a tensioner failure on an XKR. If it were my own car I would do upper & lower tensioners, water pump, all coolant hoses & a few other things just as preventative maintenance. All of which I have done to my car in addition to many many other proactive repairs. But again to restate my response I never saw a tensioner failure on an XKR.
In addition to my previous post, the tech said this from his personal experience.
Which may be just coincidence...
He said the VVT puts more stress on the upper chains.
No doubt the tensioners themselves are as good or bad on S/C or N/A engines.
I would replace 1st or 2nd gen tensioners without question!
Stefan
Stefan
OldDoc I hear ya, Your not near a good mechanic and not comfortable pulling the valve covers to check. I'm orig from ohio and now NY. It's really super simple pulling valve cover to check and any reasonable mechanic can do it i'd do the passenger side it's the easiest and some here have reused the gasket and seals so there is no cost. the people here are all sharing experience and like it or not the tensioners are a poor design (gen1/2) and will fail whether we like it or not. Some drive many miles without, others not so much and fail (recent post ). The question you have to ask are you willing to absorb the cost of a new motor if they do fail, often the result (yea a plastic piece breaks and my engine goes!) peace of mind goes a long way..hope your decision works for you
The following 2 users liked this post by Paul Pavlik:
GalaxyDriver (08-20-2014),
jimmiejag (08-20-2014)
Well, I've seen an XKR secondary tensioner failure, and it was on my car! I was fortunate in that the second I started the car and heard the blood curdling noise before the engine even turned over, I shut it down. The fact that the timing chain broke and jammed not allowing it to turn over saved my valves and allowed me to escape catastrophic engine failure. Replaced primary and secondary, all gaskets, the whole shebang. Don't let anyone feed you anymore baloney.
The following 2 users liked this post by tberg:
phyllisita (08-25-2014),
sklimii (08-27-2014)
