ZF 5 HP-24 TCM Replacement
Hi all. I had some issues with my transmission (2001 XK8 95000 Miles) and took it in for a check and the tech indicated that the TCM was bad. I found a used TCM on line but my question is do I need to have it reprogrammed or will it just plug and play? All the numbers except for the serial number match up. Thanks for any information you can provide.
I have been told it won't work right, but I bought one and had no problem. It's worth a try, and probably the worst that will happen is a message saying the ECM doesn't recognize it, or something to that effect.
If you decide to install, disconnect the neg. batt. cable first. The car will run a little rough at first and the shifts may be hard. If it doesn't behave right it will probably need reprogramming.
PaulsXK8 (02-08-2015)
RoyLittle0
05-25-2023 02:38 AM
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
