ZF gearbox fill procedure
What is the correct procedure for refilling on the these zf gearboxes.
Before i dropped the rear subframe to sort the rust out i changed the oil and filter in my gearbox it was sat to drain for a nearly a week wile i waited for a new sump pan to arrive.
Now when i put it into drive it clunks in and jolts the car.
I filled it ran it put it through the gears until it was between 40-50 and then capped it once it started overflowing.
Have i missed anything?
Received 2,434 Likes
Yea i left the sump on wile it was waiting for the filter and fluid but when i drained it the second time it was still a good litre came out easily
Yea i brought the filter and fluid as one and assumed it was right. I think i have been sent the wrong fluid from what i can see.
They sent me ATF 135.74 not ATF-MV
Busa
23
10-05-2017 12:14 PM
